Bill
I have an offer in right now on a '87 36. Since the owner has had problems with leaks in the large aft ports on the starboard side in the past, he has decided to replace these ports. He is using LEXAN -- 1/4", I believe. He has cracked two pieces during installation as he screws them down. Is this a bedding, or gasket, or material problem or just bad luck? Anyone else have problems with leaks at the large ports and difficulties with replacement? Thanks!
