Does it leak when the engine is running? Might point to the oil pressure sensor. Should check anyway.Is your oil filter sufficiently tight? Have you checked around your water pump seal to the engine? Could you have any loose bolts on the oil pan? What about the valve cover?
Doesn't really matter what you check first, check things until you find it.What to check first?
Wow that should give you a big clue for the spot.Will get the engine clean first
