40.5 leak at base of mast
i have a 40.5 which leaks a little through the wiring harness at the base of the base...i and others have discussed this problem in the past, and some suggestions are in the archieves...there've been some good ideas, but i've never been able to solve my problem...it may be the mast will have to be unstepped...however, it hasn't been a serious enough problem to go to that length....i see that you keep your 40.5 in punta gorda...i currently have mine in tampa...for 6 yrs i kept her and a prior boat at burnt store marina and commuted down on weekends...i love the sw fl area...i'm retiring in jan and will be in an out of sw fl....
