Spartite
Greg,I've had the Spartite system installed on my C-38 for two years now. No, the Spartite system did not eliminate the leaks entirely. The mast to deck joint in my boat does not leak underway but weeps a little after a long rain. The leaks are caused by the normal working of the boat and are easily caulked using a small amount of sealant. Since the gap is full of Spartite, it takes very little sealant to stop any leaks that my develop over the sailing season. Plus, you'll never have the wood wedges fall out during a spirited sail.Rodney KiddCatalina 38 #297, Flying Bear
