My 2006 model is starting to develop water leaks around the two rectangular fixed skylights above the forward part of the cabin. The skylights all seem to be part of some fixed unit, as there is a grey bead of sealant all the way around the pair of skylights. One can see that the sealant is starting to separate from the surrounding fiberglass. So, I would appreciate any and all input from whoever has tackled the job of replacing this sealant, including the best method for removing it, does the fiberglass then need sanding or priming, and the best "stuff" to seal it all up again. BTW, I would prefer not getting involved with Beneteau America as I've had nothing but headaches there.
Many thanks,
Jerry
Many thanks,
Jerry
