Leaking Lewmar Porthole
Jun 21, 2022
9
Catalina 385 Tiverton
Greetings fellow cruisers - we have a leaking Lewmar porthole and are wondering what troubleshooting you recommend to determine the proper solution. thank you.
Isolation of the leak would be where to start. Is it the
  • gasket,
  • Handle
  • Frame
  • Cracked lense
  • All of the above
If the last, time for a new unit.
Jan 4, 2006
7,440
Isolation of the leak would be where so start.
Can't begin to suggest any solution until YOU find the source of the leak. Have someone spray the porthole from outside for a starter to find the source.
