Leeking keel bolt fix
Linda,I had a problem with a leeking keel bolt on my 410. Here's what the Hunter guys recommended (that worked well). You should be able to see a groove where the keel/hull junction is after the boat is pulled. Cut a v-shaped groove about 1/2 inch deep by 1/2 inch wide with a Dremel tool, then fill this groove with 3M 5200. Apparently this area needs to flex a little and it's better to use 5200 that will give a little rather than fiberglassing over this area. You may need to use some fairing material above and below this area as needed. Next cover with epoxy and follow with bottom paint. Check with Hunter for torque specifications for your boat--they vary from model to model. If you isolate a particular keel bolt where water is seeping in, the nut should be backed off and the Dremel tool utilized around the base of the glass around the nut. Fill with 5200 as above, then replace the nut. The stainless keel bolt and nut probably won't need to be replaced unless they appear damaged (not likely). This worked well for me, and was straight from Greg Emerson in customer service. I'd also ask your surveyor exactly what he meant by his description of your discontinuity between keel and hull. If he simply meant that he saw a slightly open groove between the two, then the above fix should be satisfactory without trying to remove the keel.Best of luck,Chris Webb
