Leaking Holding Tank
C
Craig
I discovered a a leak in starboard/bow corner my holding tank that is draining to my bilge. An attempt to seal the leak from the outside was unsucessful. I don't see any access. I am assuming that the holding tank is fiberglass and I need to cut a hole above the tank and repair it from the inside. Are there other options or suggestions?
