C
Colin
The fuel pump on my Yanmar 2GM is leaking slightly. I believe the best method of fixing it would be to remove it and service it. I can only just see part of this pump owing to its location on my h335. Is it possible to remove then re-install with such limiterd visibility?Only one other possible method without engine removal is to remove what I believe is the water cooled exhaust manifold then gwet at the pump from the top.
