Z
zanziabr
We have two fixed ports on the top of our cabin which are both leaking, one worse than the other. Has anyone tried caulking to stop the leaks. If so, which caulk did you use. If rebedding is the only answer, where can we get the gasket material and what caulk/adhesive is used to hold the port in place?
