OK. Do it !!
Since you probably dont own a hood and a fresh air supply system, be especially aware of all the health risks. The only other recourse is to wear a vapor type respirator and dont forget the very important eye protection, especially when grinding. Lots of fans for circulation and definately someone outside in the cockpit if all should go south. I have done this and i can speak from experience, working in a confined area with volitile and noxious fumes can be instantly overwhelming. And of course mix all your resin outside in the fresh air, that will give you a few extra moments of fresh air for your self.Be careful.
