Leaking Diseal fuel
C
Capt Jon
I have 1989 hunter 30 T2,i have fuel leaking under fuel tank,I know I have a leak.What do I have to do to get to the fuel tank its behind the batteries.I would like some advise.JD
G
Gary Scheier
If it is behind the bulkhead
...you will probably have to cut an access hole in the aft bulkhead if it is under the transom. I had to do that to replace my holding tank on our Hunter 28. Check with Hunter about your model, as well as how to plug the hole when you have it fixed. Gary s/v Serenisea
