Leaking deck at the mast
Michael
Rainwater gets in where the mast gets through the deck. I sealed everything around the deck but still leaks. Could it be coming in through the mast? Any idea much appreciated. Thanks. Michael.
Jun 4, 2004
629
Sailboat - 48N x 89W
masts leak
Masts, especially those /w internal halyards, do leak internally. If your leak is at the partner (deck opening), hard as you've tried, you haven't actually "sealed" the mast-collar joint. Rubber splicing tape works well.
Steve O.
weep hole
Drill a small 1/4" weep hole through the mast and step at the base to let the water drain out.
Jun 4, 2004
629
thanx steve o
Great reminder Steve - tho’ even better is to cut a couple of weep SLOTS at the mast base, so NO water is retained.
