I bought an O'day 25 2 years ago and re-bedded the chainplates literally 30 minutes after I signed the papers due to slight stains in the plywood veneer. A reliable fiberglass repair shop said that both bulkheads were still fine structurally. My problem is I've rebedded the chainplates 3 times since then and have only had no leaking on the bulkhead for a short period of time. Assuming that I'm doing it right (it's not rocket science after all) I was wondering where else the leak could be coming from. It looks possible that a deck leak from the hand rail or opening port "upstream" could be travelling down the upper side of the liner onto the chainplate below the deck and then following the chainplates down below the liner into view in the cabin. Has anyone else had a mysterious leak of this nature? I've rebedded the hatch slides this year so they are not the problem. I've also ordered a couple of new ports from Rudy. Thanks for your thoughts. We love my 25, with 3 coats of Fleetwax it looks like a million bucks!
Years ago when one of my chainplate "L" brackets broke on my 86 O'Day 222, Rudy sold me some O'Day 25 chainplates and I installed them myself. To make a long story short, I had beefed up my bulkhead with oak boards prior to installing the chainplates but I was getting leaks around them so I went to a marine metal fabricator on the river and had him make up some covers and he welded them to my chainplates. I finished the job of reinstalling them with bolts, nuts, and backup plates. That was the end of my chainplate leaks.
Then I read about cleaning my deck with a household cleaner that contained Oxalic Acid. Big mistake. It cleaned the deck all right but it ate out the caulking under my gunwale molding and I had leaks up the ying yang. So I removed the moldings and caulked all the screws and screw holes and that problem was cured.
Just recently I had a leak coming in from a single screw hole on my bow toe rail. That one was so obvious after I looked at it. The first bung was missing on the Port bow toe rail and if I looked at it real close, I could see daylight under it. Not only that, but my pull over sweatshirt in that small bow compartment was soaking wet.
With that said; I don't think that I've ever had a lifeline stanchion leak and I wouldn't remove one unless I knew absolutely sure that it was leaking from it.
Do like I did. Have someone run a garden hose over the suspected area of your boat and go in the cabin and do some looking and feeling around.
One of my newest leaks was a tabernacle bolt. A tiny drop was forming on one of the bolts from around the threads. What a pain in the butt that one was.
My mast tabernacle sits on a block of Trex now and it is now bedded with gray Butyl Tape. It was sitting on a Teak block prior to the leak. Hopefully, that problem is solved.
I think that the easiest job was the gunwale molding but it has to be done with the boat on the hard. The caulking under that molding is only good for about ten years and all we're taking about is removing the molding and caulking all the screw heads and the screws that hold that molding on. If you have a vinyl molding, you're going to need a caulking that will not have an adverse reaction to the plastic. Dow Corning 795 is good for vinyl moldings, port lights, and plastic hatches.
If you opt for welded chainplate covers on your boat like I did, you need to take into consideration, where the bolts will come through the deck in relation to the V birth side of your bulkhead. There's the thickness of the bulkhead to consider for the backup plates and the nuts for the bolts.
As far as caulking is concerned, I'm getting to like this Butyl Tape. Check out Main Sail's thread on bedding deck hardware. It's very informative.
Good Luck!
Joe
