Michael Clark
Has anyone who owns a 1983 Hunter 31 experienced leaks (fresh water or rain water) in the qtr. berth and starboard cockpit locker? I've had this problem since late last fall and cannot find where the water is finding it's way in. I've sprayed down the entire cockpit with water hoping I would see where the water is finding it's way in the boat but to no avail.The water (which is definetely fresh/rain water) runs into the qtr. berth from the bulkhead seperating the qtr. berth from the rest of the underneath cockpit area. Sometimes there is more water ponding in the qtr. berth and starboard cockpit than other times. Sometimes I find water only in the qtr. berth and not the rest of the cockpit locker. Sometimes there is more water in both than other times. Usually I can mop up the water with a towel or two. However, the bulkhead stays wet all the time and I'm worried about the degregation of the wood seperating the two areas. Not to mention I can't keep any cusions in the qtr. berth while it's continuing to leak. Any help or suggestions on this matter is greatly appreciated. I can be contacted directly at michaelc89@earthlink.net or on the HOW web site
