I had a short haul friday and now i have a leak.
Bilge level rises 3 inches per hour.
The mechanic pulled my old 1 inch prop shaft out so he could get a new one made and put an extra one that he had laying around back in its place.
At first I thought it was the shaft seal that was leaking because his old shaft was right on 1 inch diameter and my shaft was about 0.012 inches bigger in diameter.
But I can see no water at the shaft seal. Surely I would see very visible amounts of water coming in?
The other thing that happened was with the travel lift operator. For the first time in my experience, he lifted my boat with the aft strap going around the bottom of the keel. His first try when he lifted to take a look, he had the strap on the keel, but right on the bottom hinge for the rudder. I told him to put it back in and reposition which he did and moved it a couple of feet forward.
Could this have caused a leak in my keel?
Normally, they lift my boat with the strap on the hull above the propeller.
gh[Non-text portions of this message have been removed]
