Leak from above the rudder shaft coupling
L
Larry Whitmire
Help!!! I have a leak from the coupling above the rubber hose on the rudder shaft. It only leaks when under power. I am thinking because the stern is lower in the water when under power. Has anyone had this problem before? If so how did you correct the problem? Thank You!
John New
Try this....
I found that tightening the bolts on the rudder stuffing box helped with this problem on my boat. If your boat has an Edson system, there should be a flange surrounding the rudder post below the rubber with three bolts (see the link for a picture of what I'm talking about). Tightening these down might help.
