Tim Op't Holt
I noticed yellow fluid in the bilge below the Yanmar on my H31. There is a major cut in the belt as well. My assumption is that there is an antifreeze leak. I see some of this yellow dried on the forward portion of the underside of the oil pan. Can anyone help with the possible source of this leak? As long as I have the belts off for replacement, I think I will change the fresh water pump impellar. Your thoughts will be appreciated.Tim
