leak above shelf in aft head
6
Hunter 42 Passage CC New Smyrna Beach, FL
We have a 1994 hunter 42 center cockpit. the aft head leaks seemingly from a seam above the upper shelf. appears to be from where the deck joins the hull. Any similar problems fixed?
Oct 24, 2011
258
Lancer 28 Grand Lake
I had an irwin citation 35, and water poured in all over, due to that hull deck seal, I tried everything, nothing worked, on the boat i have now, have the same problem, so have taken the toe rails off, and intend to glass the joint, then re bed the toe rails. If it just one leak you have, i would firstly make sure its not from a deck fitting, which is a very easy fix, by removing it, and re bedding it, if you are certain its the toe rail, i would try taking out the screws in that area, and put them back in, with plenty of sealant in them, if that dosent work, i wouldnt waste my time trying anything else, i would take the rail off and re bed it. I must have used ten tubes of silicone, and variouse other sealants on the citation, and it made not the slightest bit of difference.
