Leading Lines Aft - O'Day 25
13
- - Anchorage, AK
I am getting ready to properly run my halyards aft; the previous owner sort of jury rigged it. I have a stainless steel halyard organizer plate that mounts under the mast, and the cams and clutches are already mounted on the cabin top on either side of the companion way. I intend to mount a deck organizer on the cabin top, outboard of the mast step, to lead the halyards through. Any tips or things to avoid in this procedure? Also, do I need flat mounted turning blocks between the mast base and deck organizer? Or, can I just put a pulley on the mast base organizer plate, run the halyard through there, and then out to the deck organizer and so back to the cockpit? Sorry for the lengthy post, and thanks.
Mullet
Dec 8, 2004
40
- - Texas
I'm going to use
standup blocks at the mastbase, then double cheek blocks to lead the lines aft between the handrails and the hatchcover rails to the clutches.
May 31, 2004
858
Catalina 28 Branford
Check the archives
I'm pretty sure that there are photos of this exact job somewhere in the archives of this site.
Jun 15, 2004
13
- - Anchorage, AK
Thanks
for the suggestions. I have searched the archives in vain for some photo. If anyone knows of one that I am missing, please advise.
Jun 2, 2004
1,438
Oday 25 pittsburgh
Kevin, There is a photo article
in the 25 O'Day section. Go to the top of this page. Click on Boat Specs (in the boat info center tab). Then go down the left margin to 25. Click 25. The scroll down to Photo Articles. and click on Lines aft. It has pictures and everything. r.w.landau
