Lead Shot Onboard
Nov 28, 2026
2
Hunter 36 New Orleans
Hi yall, I bought a Hunter 36 three years ago and it had a non-working generator in the port stern locker. I finally had that removed. I also took out 21 bags of lead shot that the previous owner had behind the stern bunk on the starboard side. When I removed the shot (525 lbs) my boat was listing to port. Any ideas on why it’s listing and why that shot might have been added? I figured it was to balance the generator but now thinking it’s something else. Thanks!
Likes: Timm R Oday25
The previous owner chose to use the lead shot as a quick fix for leveling (balancing) the boat. @JoeWhite is spot on.
The challenge with this approach is that it adds weight to the boat. The boat sits a bit lower in the water. This creates more drag, so while the boat is level, it goes slower.:wahwah:
I would look at what is on the port side of the boat, causing the boat to list to port. Then remove anything that is not necessary. If you consider the items necessary, look to see what can be easily moved to the starboard side so your boat sits level without adding weights.
Likes: NolaCoop
I can't know, of course, but the generator probably didn't weigh nearly as much as the lead shot. It seems likely the shot was added to improve the trim, as has been established. Don asked about the batteries. Where is, or was, the fuel tank for the generator located? I assume there's no fuel left after removing the generator. Was the generator decommissioned? Is there an empty fuel tank? That could also be affecting your trim.
Did you see the boat out of the water? Is the keel aligned with new keel bolts? A 36' sailboat should be pretty tolerant of a couple hundred pounds moving around on deck or otherwise. I hope, if you replace the lead shot it is secured so a knock down or severe heel doesn't allow your ballast to shift.
If it was in a confined locker aft, 500+ pounds could also raise the bow and sink the stern. This would have a significant effect upon the helm and your weather trim. You might notice greater weather helm with the bow deeper in the water causing the CLR to move forward.
Maybe anchor chain could replace the lead shot, something you use anyhow, but not while under sail.
-Will
How many degrees is the boat listing to port? It is not unusual for boats coming out of the factory to list a little. Laying up a glass hull is not a precise science. A little too much resin on the port side and a little short on the resin on the Starboard side could cause a list of a degree or two. Owner additions, be it equipment, tools, stores or what ever can accentuate the heel. Is there an outboard hanging on the port side of the pushpit?
Likes: NolaCoop
7,755
Alden 50 Sarasota, Florida
This is why I stopped bothering to respond thoroughly - when the OP who read these replies including my q about where his batteries are can’t be bothered answering by helping us help him.
Nov 28, 2026
2
Don, appreciate your response. My batteries are in the port locker but I don’t think it’s enough to cause the list. Another Hunter 36 owner on my dock has no ballast in the same location so it’s just odd to me. I may try to contact the original owner to understand why they added the lead shot originally. Than you!
7,755
Thanks for responding. How many and what type/size are the batteries? Depending on distance from the CL, even one or two 4Ds or 8Ds could have a noticeable effect. Battery location might not be the cause but it certainly can contribute to your list.
Sep 26, 2008
813
Hunter 340 0 Wickford, RI
Would be a good alternative to all that lead. And easier to handle if you do in fact need balance in your boat. After you assess the other items mentioned by others to offset the load.
In either case though…….
You are soon to become the best friend of any person who reloads bullets. So do not discount what you have in future value towards a nice piece of electronics, batteries etc. There is value in what you hold, regardless of the actual size of the lead shot. Just my advice to you when and if you decide to not use the lead.
  • Helpful
JamesG161
Feb 14, 2014
8,114
Hunter 430 Waveland, MS
Weight of Generator is why the Lead shot was needed.
I suggest putting Lead back or install a new Generator.
Jim...
But the OP says without the generator or the lead the boat leans to port. Putting a generator back on the port side will just mean you need more lead to balance it out.
Very good question. The boat weighs over 13,000 pounds. I can’t imagine 525 pounds is compensating for more than a couple degrees of list. Personally I’d rather live with a couple degrees of list, or look to balance that out by moving tools or batteries, rather than lugging around an extra 500 pounds, especially in the stern where it could add to hobby-horsing.
