H
Hal
I just purchased a 1975 Mariner 2+2 centerboard model, and have inspected the boat more closely after getting it home. There dose not appear to be any lead ballast in the bilge. Or is it located somewhere else and not visible? I believe there is supposed to be 250 lbs of ballast in the centerboard model, or am I mistaken? If this is missing, where can I get lead ballast? Another question too: I noticed that two supports have been placed under the cockpit floor, one may be older (maybe original and part of the construction design), the other looks newer. Problem is, the newer one has forced the cockpit floor up too far and there are cracks in the gelcoat. Does anyone know if these are original components? Is it likely the fiberglass cockpit flooring is damaged too? How should this repair be done if necessary?Thanks for any ideas!Hal
