Lead Acid Batteries
We know all there is to know about these batteries... Yes... No... maybe?
While looking at the subject and refreshing my thinking, especially in light of all the interest in LiFePO4 batteries, I came across this compact review of Lead Acid batteries be them Flood, AGM, Gel etc.
This guide was published on Panbo.com and produced by Luis Soltero.
I hope this helps you with your battery questions.
JamesG161
Feb 14, 2014
7,755
Hunter 430 Waveland, MS
One other Chemical Fact...
The Earth continues to make new Lead [Pb] each day.
Jim...
PS: No new Lithium [Li] made on Earth each day.:(
Likes: SailingLoto
This diagram is VERY not correct. Actually I think it might be the diagram for the hydrolysis of water and has nothing to do with a battery. For example, in this diagram, water is consumed and converted into hydrogen and oxygen gas. The gas would leave and very soon your battery would run dry. In fact, the exact opposite reaction, (the conversion of 2H2 and O2 into 2H2O) is how a fuel cell opperates. In this scenario, your battery would constantly consume water and electricity would need to be added IN....
In a Pb-Acid battery H+ is produced at the anode but on the cathodic side of the cell it combines with the hydrogen sulfate anion to produce sulfuric acid. It does not pick up an electron and become a neutral hydrogen atom.
Likes: JamesG161
Dec 4, 2023
137
Hunter 44 Portsmouth
According to the source I'm looking at, How Boat Things Work: An Illustrated Guide (very cool book - recommend), the reaction they're showing is indeed hydrolysis; which occurs when the battery is charging and becomes overcharged. My understanding is that there's no PbSO4 left to react and make PbO2 on the positive electrode, so the reaction becomes straight up hydrolysis.
My source doesn't explicitly say this, but a quick Google search says that the hydrolysis reaction occurs a little bit as the battery tops off due to differences in charge of the individual cells (some cells are slightly overcharged while others are still charging).
JamesG161
Feb 14, 2014
7,755
the reaction they're showing is indeed hydrolysis; which occurs when the battery is overcharged.
This is the reason you need a Regulated Battery Charger.
That type Charger uses the Amperage as feed back to properly control it.
Most Chargers have a Balance Charge mode when 2 or more Lead/Acid [not AGM] are in parallel.
During that balance charge, the Batteries can make Hydrogen. :cool:
Safety First
Jim...
JamesG161
Feb 14, 2014
7,755
Using @rgranger Over Cell Balance of 2.041 Volts
When fully charged and connecting 6 plates together then...
2.041 X 6 = 12.246 VDC
The fully charged standard Volts on your Lead/Acid Battery :clap:
Jim...
Correct!:beer:
Were we talking about charging? Maybe I jumped the gun on my critique? I thought the diagram was showing the discharge of the battery. Anyway, the charging should be the reverse of the discharge reaction unless you over charge or charge too aggressively.
BarryL
May 21, 2004
1,064
Hello,
You need to add this statement to your first picture:
An unwanted (and unfortunate) side reaction occurs during the charging cycle. Passing a current through an electrolyte causes water to disassociate into hydrogen (H2) and oxygen (O2). This process is known as electrolysis and releases hydrogen at the battery’s negative pole and oxygen at the positive pole.
Without that statement your picture is very confusing.
Barry
JamesG161
Feb 14, 2014
7,755
Most Radioactive Elements end their Decay series with LEAD [Pb]
A few exceptions are the Radioactive Gases. Example is Argon [Ar], which ends its Decay series with no electron Helium [ He-4].
No new Lithium [Li] is made on Earth.
I will stick with my Boat's Lead/Acid batteries. :pimp:
Jim...
Likes: Ward H
JamesG161
Feb 14, 2014
7,755
That is why in my Post #2 above I added the picture, which was also taken from the same Article that @jssailem linked in his original post.
SBO's top Chemist is @rgranger so listen to him.
I am a Chemical Engineer, who makes his chemistry manufactured for our non laboratory size. :biggrin:
Jim...
I don't think that is an accurate statement. There are 26 known isotopes of Argon but most are exceedingly rare. The only isotopes of appreciable concentration are Argon-36, Argon-38 and Argon-40 with Argon-40 making up the vast majority. Argon 36 and Argon 38 are made in the furnace of stars but 40 is the final decay product of radioactive potassium. BUT all three isotopes are stable. There are radio active isotopes of argon but most of those are someplace on a decay path and are VERY rare and none that I could find end in Helium.
When a particle containing two protons and two neutrons is ejected from a nucleus we call that an alpha particle and it does look like a "no electron" helium but ..it is very high energy and will capture electrons at some point and become a helium atom.
Here are some examples of Argon decay schemes.
SBO only allows 10 attachements but... I did not see any other Argon decay series ending with Helium.
dLj
Mar 23, 2017
4,322
While the article was an interesting overview, what I've still never seen well explained is the sulfation process.
That would have gotten me much more interested in reading that in its entirety.
dj
