Mast wiring
the mast is not a suitable 12V system ground. the mast is generally grounded ONLY as lightning protection to a keel bolt or similar. For it to be used as a 12V ground the - terminal of the battery would also need to be grounded to the keel bolt, (or wherever the mast is grounded). This is not a good arrangement in the case of a lightning strike.The 2 wire plug that exists is probably 12V and 12V ground, (- batt terminal), since that is all that would have been needed for the original steaming light. Put a meter across the plug to the light and see. If there is a good light bulb in the steaming light socket it will read short. don't trust that however if you don't at first see a short. Lamp sockets have been known to corrode. Jump directly across the lamp socket terminals with a wire and see if it then reads short at the plug....or twist the wires together at the lamp socket insuring you have a connection and try with the meter again. (its also good practice to check continuity of each of the plug wires to the mast ensuring neither is frayed and shorted to the mast). since you need to switch steaming, deck, and anchor lights separately you will need 3 hot/switched wires and a common ground...4 wires total up the mast and to the batt. (always pull a spare while you're at it so make that 5 wires). i am going to pull 4 or 5 wires so i will have 1-2 extra wires. that way the wires are already there if i want to later add spreader lights or if i simply have a wire go bad. A single 1x4 or 1x5 shielded is probably preferable since the whole mess is insulated. there would however be some issues "breaking-out" the individual wires for the steaming/deck light so I imagine I am going to do individual wires myself.the attached link seems to have about the best prices and assortment so i will probably get all my stuff from them when i am sure i have a complete list....i hate to have to order multiple times and pay shipping each time!
