Lazy Jack Question
250
Hunter 41 Longport,NJ
How well will a lazy jack work with a only partially battened mainsail ? I have a 1981 Hunter 33 and am considering either purchasing a kit or trying to make one myself from some of the very nice posts on this forum. Any advice appreciated.
Jun 2, 2004
5,802
Mine works well enough with just the four short battens. Location of the vertical lines is key but not critical. I did eventually move mine back from their original hooks. Mine retracts against the mast. I found that by going farther back to a bale that was already there I was able to get a better fold on top of the boom. That bale is almost at the aft end. Then there are the other lines between the aftmost and the mast that can be moved forward or back to get the best collection. Unfortunately no pictures because they are always against the mast.
BobM
Jun 10, 2004
3,269
S2 9.2A Winthrop, MA
My experience
Up is much harder than down. It is easy to snag a batten on the jacks, especially if you are relying on someone who is unclear on the concept of "keep the boat into the wind" as I am. Down is a piece of cake, especially if you flake your main properly. Mine practically drops pre-flaked now. I would like to modify them so I can pull them against the mast underway though...if only to avoid chafe.
Keep the boat into the wind is harder to do, regardless of whether you're new or an old salt.
What I do is simple: I pull back only one side of the lazy jacks, and then off the wind a bit so that the sail is blown a little bit to the side where the lazy jacks aren't. Main sail goes up smoothly all the time.
Trying to get a main sail, with or without battens, up while still having the lazy jacks in place is very hard to do.
Jul 12, 2004
19
-chrysler -c26 full keel longwood
with practice they will work great for you. I would suggest making your own the manufactured ones are good but severly overpriced, and usely you will have to modify them any way
Mar 22, 2004
733
Hunter 30 Vero Beach
Lazy Jacks
There was a really good article in either Sail magazine, or good old boat a couple of months back on the positioning of the lines for lazy jacks. I'll have to look for the article. For a 30 ft boat, you could make them for under $100
Dave S
Sep 27, 2008
250
Re: Lazy Jacks
This is really helpful - I found the artcle in "This Old Boat" - have another question though - I have seen the control lines either come down the mast, or down the length of the boom. I prefer the latter, but am also thinking about putting in a single line jiffy reefing system - seems like alot of hardware and lines on the boom. Any advise on that one ? Does anyone have both running down their boom and if so, how ha that worked out for you ?
pogo2
Sep 26, 2008
97
Newport 30 Mklll North Tonawanda, NY
single line reefing & lazy jacks
I installed both on my Newport 30 and they work just fine, I don't have the lazy jacks deployed while raising the main, it just eliminates a bunch of headaches. I don't use the lazy jacks when reefing the main either, it always seems that a batten get hung up some place and when sailing alone its no fun trying to get it all straiughtened out. All line lead to the cockpit, so for single handed sailing the lazy jacks are the second best thing I've installed on my boat. I did the instalation of the lazy jacks my self, I'll send pics some time soon.
Jun 7, 2004
265
- - Milwaukee
We have them on our h356, with two partial battens low and two full battens high. works well, especially if i reach up and tuck the back end of the sail in under the l.j. after lowering. the point about snagging on the way up is valid, but its the two full battens i have to watch for on mine, so that's a different issue.
Aug 5, 2006
121
Hunter 33 brisbane
A good idea is to spread the lazy jacks wide using shock cord out to the extremities of the middle spreaders. Snagging is almost eliminated. The gap in mine at the shock cord is about 1 metre and this does not inhibit the boom movement when running.
Jun 21, 2007
2,118
- I found the article in "This Old Boat" -
Dear spadaforaj:
I wasn't as successful locating the article. If possible, can you advise the actually web link URL?
Thanks in advance
rardi
544
Bristol 43.3 Perth Amboy
Lazy Jacks
I have them on my Bristol 43.3. Originally, only the top battens were full length. The lazy jacks did an ok job keeping the main under control. They do work better with the full length battens since I modified the sail.
A key trick to keep the lazy jacks from fouling on the sail on the way up, it to loosen them and bring them forward. I loosen them up and pull them forward and tension them into the reefing hooks.
pogo2
Sep 26, 2008
97
ezjax system
this is where I found the information on instilation and measurement for the system I have
www.ezjax.com
Jun 21, 2007
2,118
Re: ezjax system
Dear Pogo2:
Many thanks!
