I thought you guys might like to see what I came up with for a third wheel for the trailer tongue for use in launching the boat from a ramp with a strap. (see new photos posted)
I welded up an arm using a spindle and hub that is the same size as what is on the trailer. I bolt the spare tire for the trailer to the hub. Usually the arm is pinned in the upright position (doubles as the spare tire carrier).To launch the boat I put some sturdy chocks behind the trailer wheels, and unhitch the trailer from the truck. Next I pull a pin, rotate the arm with the spare tire 180 degrees down, repin the arm, lower the tongue jack so the third wheel is bearing the tongue weight, swing the tongue jack up and connect a 30' strap to the trailer and the truck. I then pull the truck and trailer slightly forward, pull out the sturdy chocks and back the trailer into the lake until the boat floats off. I should mention that I do this right at the edge of the water, so that if something should go awry, and the trailer gets away, it doesn't have far to roll into the water..... -Tim
