Nope...unfortunately no.....
No EYEBOLT on the keel. As a matter of fact, the Beneteau First 235 could not be done this way even if it did as I dont think it's a direct line from any keel bolt to lift. Not only that, but instead of studs with a nut like most keels, the Beneteaus like the 235 have actual keel BOLTS that go into the keel. When you remove a keel bolt, it's literally turning the entire bolt, not ye olde nut.So I dont think the 235 has any provision for lifting in this fashion, nor do a estimate there really be any feasible way to mod it either.It's the slings with the spreaders at top to keep compresson off the boat.kellyhttp://beneteau235.comhttp://beneteau235.com/forum
