I would guess the engine is not getting enough fuel, unless the prop was recently changed. It doesn't take much fuel to rev an unloaded engine.However, if you have it in gear, the prop is turning, when you increase the throttle, does a lot of black smoke come out of the exhaust?An incorrectly sized prop would overload the motor, and probably cause a lot of black (unburned fuel) smoke while loaded down at low rpms.If you have it in gear, prop turning and throttle it up and there is no black smoke, then it is likely a fuel starvation/quality problem.The fact that it doesn't want to idle very smoothly suggests a possible injector problem. I've run Diesel Kleen additive in the fuel of my trucks when they start to "misfire"and it seems to help clean them. You could pull the injectors and get them pop tested to check the spray pattern and fuel volume of the spray.Just curious as to how you know you are not getting air in the system? You could also try loosening the injector line to the injector enough to let fuel leak out, thereby preventing the injector from firing.Do this test while idling, out of gear, and if disabling one injector doesn't make that much difference to rpms or smoothness, the problem is probably that injector.If disabling each injector yields the same result, then either both injectors are faulty or fine. I haven't done this on a two cylinder motor (only v-8's) so it might not work, but could be worth a try.Obviously, take care to not set yourself or boat on fire. My experience is that only a few drops leak out on each pulse of the injection pump. If you loosen the nut on the injector line and bubbles come out, you know there is air in the system.Another possible problem is timing. If someone loosened and moved or removed and replaced the injection pump, the timing could be off. If the factory paint is intact around the pump, I would look at other possible problems first. That would be my guess as just some guy who is not a diesel mechanic and just guesses about diesels. -Tim From: "bundchen1263@... [AlbinVega]"
AlbinVega@yahoogroups.com To:
AlbinVega@yahoogroups.com Sent: Friday, June 23, 2017 8:37 AM Subject: [AlbinVega] Re: Launched yesterday. Few questions.
UPDATE: Hi folks i am trying get this beta bz482 running. i am trying to get help trouble shoot the problem also at facebook group. I wanted to mentioned it here as well since not everyone has membership to both forum/sites. tank/fuel system/filters etc clean, no water, no air getting in the system. Engine getting enough fuel, tank vents, extra fuel returns to the tank without issue. i had to break the seal of the factory set idle speed to turn it up, now it idles around 820(correct speeed according to the manual) before, it was idling around 600, not smooth and barely staying on. That made me think little bit because it may indicate a problem somewhere else. Why would i need to mess with factory setting to to set the correct idle speed? Anyway the engine has no problem revving up to 4k WHILE the transmission disengaged, idling. As soon as you engage the transmission, now the coupler and the shaft starts turning, forward or reverse, the engine is NOT able to see over 650-700 rpm, very slovly turning the shaft which gives you a knot or so forward or reverse speed. I have disconnect the coupler from the shaft to see how things work and again observed the engine revving up to 4k screaming like an eagle, turning the flange that sticks out of the gear box at highest rpm rated for the engine. Once connected to the shaft, above mentioned symptoms returns.The engine is beta bz482, very low hours, the fuel, air, oil filters i ve replaced was still factory installed, red painted stuff. the shaft and prop seems to be brand new, maybe few hours. THAT brings us to the point: is my prop too big or sized wrong etc?one more not: It is very easy to turn the shaft, coupler by hand, indicating its not restricted, also the ATF is newly replaced. Thanks in advance. have been talking to beta marine NC. Yes very supportive, the water here is very murky and have no info about the prop. before i decide to pay for lift and maybe replace the prop, i would like to eliminate all other possibilities.
#ygrps-yiv-1696855592 #ygrps-yiv-1696855592yiv7582130504 #ygrps-yiv-1696855592yiv7582130504 --
#ygrps-yiv-1696855592yiv7582130504ygrp-mkp {
border:1px solid #d8d8d8;font-family:Arial;margin:10px 0;padding:0 10px;}
#ygrps-yiv-1696855592 #ygrps-yiv-1696855592yiv7582130504 #ygrps-yiv-1696855592yiv7582130504ygrp-mkp hr {
border:1px solid #d8d8d8;}
#ygrps-yiv-1696855592 #ygrps-yiv-1696855592yiv7582130504 #ygrps-yiv-1696855592yiv7582130504ygrp-mkp #ygrps-yiv-1696855592yiv7582130504hd {
color:#628c2a;font-size:85%;font-weight:700;line-height:122%;margin:10px 0;}
#ygrps-yiv-1696855592 #ygrps-yiv-1696855592yiv7582130504 #ygrps-yiv-1696855592yiv7582130504ygrp-mkp #ygrps-yiv-1696855592yiv7582130504ads {
margin-bottom:10px;}
#ygrps-yiv-1696855592 #ygrps-yiv-1696855592yiv7582130504 #ygrps-yiv-1696855592yiv7582130504ygrp-mkp .ygrps-yiv-1696855592yiv7582130504ad {
padding:0 0;}
#ygrps-yiv-1696855592 #ygrps-yiv-1696855592yiv7582130504 #ygrps-yiv-1696855592yiv7582130504ygrp-mkp .ygrps-yiv-1696855592yiv7582130504ad p {
margin:0;}
#ygrps-yiv-1696855592 #ygrps-yiv-1696855592yiv7582130504 #ygrps-yiv-1696855592yiv7582130504ygrp-mkp .ygrps-yiv-1696855592yiv7582130504ad a {
color:#0000ff;text-decoration:none;}
#ygrps-yiv-1696855592 #ygrps-yiv-1696855592yiv7582130504 #ygrps-yiv-1696855592yiv7582130504ygrp-sponsor #ygrps-yiv-1696855592yiv7582130504ygrp-lc {
font-family:Arial;}
#ygrps-yiv-1696855592 #ygrps-yiv-1696855592yiv7582130504 #ygrps-yiv-1696855592yiv7582130504ygrp-sponsor #ygrps-yiv-1696855592yiv7582130504ygrp-lc #ygrps-yiv-1696855592yiv7582130504hd {
margin:10px 0px;font-weight:700;font-size:78%;line-height:122%;}
#ygrps-yiv-1696855592 #ygrps-yiv-1696855592yiv7582130504 #ygrps-yiv-1696855592yiv7582130504ygrp-sponsor #ygrps-yiv-1696855592yiv7582130504ygrp-lc .ygrps-yiv-1696855592yiv7582130504ad {
margin-bottom:10px;padding:0 0;}
#ygrps-yiv-1696855592 #ygrps-yiv-1696855592yiv7582130504 #ygrps-yiv-1696855592yiv7582130504actions {
font-family:Verdana;font-size:11px;padding:10px 0;}
#ygrps-yiv-1696855592 #ygrps-yiv-1696855592yiv7582130504 #ygrps-yiv-1696855592yiv7582130504activity {
background-color:#e0ecee;float:left;font-family:Verdana;font-size:10px;padding:10px;}
#ygrps-yiv-1696855592 #ygrps-yiv-1696855592yiv7582130504 #ygrps-yiv-1696855592yiv7582130504activity span {
font-weight:700;}
#ygrps-yiv-1696855592 #ygrps-yiv-1696855592yiv7582130504 #ygrps-yiv-1696855592yiv7582130504activity span:first-child {
text-transform:uppercase;}
#ygrps-yiv-1696855592 #ygrps-yiv-1696855592yiv7582130504 #ygrps-yiv-1696855592yiv7582130504activity span a {
color:#5085b6;text-decoration:none;}
#ygrps-yiv-1696855592 #ygrps-yiv-1696855592yiv7582130504 #ygrps-yiv-1696855592yiv7582130504activity span span {
color:#ff7900;}
#ygrps-yiv-1696855592 #ygrps-yiv-1696855592yiv7582130504 #ygrps-yiv-1696855592yiv7582130504activity span .ygrps-yiv-1696855592yiv7582130504underline {
text-decoration:underline;}
#ygrps-yiv-1696855592 #ygrps-yiv-1696855592yiv7582130504 .ygrps-yiv-1696855592yiv7582130504attach {
clear:both;display:table;font-family:Arial;font-size:12px;padding:10px 0;width:400px;}
#ygrps-yiv-1696855592 #ygrps-yiv-1696855592yiv7582130504 .ygrps-yiv-1696855592yiv7582130504attach div a {
#ygrps-yiv-1696855592 #ygrps-yiv-1696855592yiv7582130504 .ygrps-yiv-1696855592yiv7582130504attach img {
border:none;padding-right:5px;}
#ygrps-yiv-1696855592 #ygrps-yiv-1696855592yiv7582130504 .ygrps-yiv-1696855592yiv7582130504attach label {
display:block;margin-bottom:5px;}
#ygrps-yiv-1696855592 #ygrps-yiv-1696855592yiv7582130504 .ygrps-yiv-1696855592yiv7582130504attach label a {
#ygrps-yiv-1696855592 #ygrps-yiv-1696855592yiv7582130504 blockquote {
margin:0 0 0 4px;}
#ygrps-yiv-1696855592 #ygrps-yiv-1696855592yiv7582130504 .ygrps-yiv-1696855592yiv7582130504bold {
font-family:Arial;font-size:13px;font-weight:700;}
#ygrps-yiv-1696855592 #ygrps-yiv-1696855592yiv7582130504 .ygrps-yiv-1696855592yiv7582130504bold a {
#ygrps-yiv-1696855592 #ygrps-yiv-1696855592yiv7582130504 dd.ygrps-yiv-1696855592yiv7582130504last p a {
font-family:Verdana;font-weight:700;}
#ygrps-yiv-1696855592 #ygrps-yiv-1696855592yiv7582130504 dd.ygrps-yiv-1696855592yiv7582130504last p span {
margin-right:10px;font-family:Verdana;font-weight:700;}
#ygrps-yiv-1696855592 #ygrps-yiv-1696855592yiv7582130504 dd.ygrps-yiv-1696855592yiv7582130504last p span.ygrps-yiv-1696855592yiv7582130504yshortcuts {
margin-right:0;}
#ygrps-yiv-1696855592 #ygrps-yiv-1696855592yiv7582130504 div.ygrps-yiv-1696855592yiv7582130504attach-table div div a {
#ygrps-yiv-1696855592 #ygrps-yiv-1696855592yiv7582130504 div.ygrps-yiv-1696855592yiv7582130504attach-table {
width:400px;}
#ygrps-yiv-1696855592 #ygrps-yiv-1696855592yiv7582130504 div.ygrps-yiv-1696855592yiv7582130504file-title a, #ygrps-yiv-1696855592 #ygrps-yiv-1696855592yiv7582130504 div.ygrps-yiv-1696855592yiv7582130504file-title a:active, #ygrps-yiv-1696855592 #ygrps-yiv-1696855592yiv7582130504 div.ygrps-yiv-1696855592yiv7582130504file-title a:hover, #ygrps-yiv-1696855592 #ygrps-yiv-1696855592yiv7582130504 div.ygrps-yiv-1696855592yiv7582130504file-title a:visited {
#ygrps-yiv-1696855592 #ygrps-yiv-1696855592yiv7582130504 div.ygrps-yiv-1696855592yiv7582130504photo-title a, #ygrps-yiv-1696855592 #ygrps-yiv-1696855592yiv7582130504 div.ygrps-yiv-1696855592yiv7582130504photo-title a:active, #ygrps-yiv-1696855592 #ygrps-yiv-1696855592yiv7582130504 div.ygrps-yiv-1696855592yiv7582130504photo-title a:hover, #ygrps-yiv-1696855592 #ygrps-yiv-1696855592yiv7582130504 div.ygrps-yiv-1696855592yiv7582130504photo-title a:visited {
#ygrps-yiv-1696855592 #ygrps-yiv-1696855592yiv7582130504 div#ygrps-yiv-1696855592yiv7582130504ygrp-mlmsg #ygrps-yiv-1696855592yiv7582130504ygrp-msg p a span.ygrps-yiv-1696855592yiv7582130504yshortcuts {
font-family:Verdana;font-size:10px;font-weight:normal;}
#ygrps-yiv-1696855592 #ygrps-yiv-1696855592yiv7582130504 .ygrps-yiv-1696855592yiv7582130504green {
color:#628c2a;}
#ygrps-yiv-1696855592 #ygrps-yiv-1696855592yiv7582130504 .ygrps-yiv-1696855592yiv7582130504MsoNormal {
margin:0 0 0 0;}
#ygrps-yiv-1696855592 #ygrps-yiv-1696855592yiv7582130504 o {
font-size:0;}
#ygrps-yiv-1696855592 #ygrps-yiv-1696855592yiv7582130504 #ygrps-yiv-1696855592yiv7582130504photos div {
float:left;width:72px;}
#ygrps-yiv-1696855592 #ygrps-yiv-1696855592yiv7582130504 #ygrps-yiv-1696855592yiv7582130504photos div div {
border:1px solid #666666;min-height:62px;overflow:hidden;width:62px;}
#ygrps-yiv-1696855592 #ygrps-yiv-1696855592yiv7582130504 #ygrps-yiv-1696855592yiv7582130504photos div label {
color:#666666;font-size:10px;overflow:hidden;text-align:center;white-space:nowrap;width:64px;}
#ygrps-yiv-1696855592 #ygrps-yiv-1696855592yiv7582130504 #ygrps-yiv-1696855592yiv7582130504reco-category {
font-size:77%;}
#ygrps-yiv-1696855592 #ygrps-yiv-1696855592yiv7582130504 #ygrps-yiv-1696855592yiv7582130504reco-desc {
font-size:77%;}
#ygrps-yiv-1696855592 #ygrps-yiv-1696855592yiv7582130504 .ygrps-yiv-1696855592yiv7582130504replbq {
margin:4px;}
#ygrps-yiv-1696855592 #ygrps-yiv-1696855592yiv7582130504 #ygrps-yiv-1696855592yiv7582130504ygrp-actbar div a:first-child {
margin-right:2px;padding-right:5px;}
#ygrps-yiv-1696855592 #ygrps-yiv-1696855592yiv7582130504 #ygrps-yiv-1696855592yiv7582130504ygrp-mlmsg {
font-size:13px;font-family:Arial, helvetica, clean, sans-serif;}
#ygrps-yiv-1696855592 #ygrps-yiv-1696855592yiv7582130504 #ygrps-yiv-1696855592yiv7582130504ygrp-mlmsg table {
font-size:inherit;font:100%;}
#ygrps-yiv-1696855592 #ygrps-yiv-1696855592yiv7582130504 #ygrps-yiv-1696855592yiv7582130504ygrp-mlmsg select, #ygrps-yiv-1696855592 #ygrps-yiv-1696855592yiv7582130504 input, #ygrps-yiv-1696855592 #ygrps-yiv-1696855592yiv7582130504 textarea {
font:99% Arial, Helvetica, clean, sans-serif;}
#ygrps-yiv-1696855592 #ygrps-yiv-1696855592yiv7582130504 #ygrps-yiv-1696855592yiv7582130504ygrp-mlmsg pre, #ygrps-yiv-1696855592 #ygrps-yiv-1696855592yiv7582130504 code {
font:115% monospace;}
#ygrps-yiv-1696855592 #ygrps-yiv-1696855592yiv7582130504 #ygrps-yiv-1696855592yiv7582130504ygrp-mlmsg * {
line-height:1.22em;}
#ygrps-yiv-1696855592 #ygrps-yiv-1696855592yiv7582130504 #ygrps-yiv-1696855592yiv7582130504ygrp-mlmsg #ygrps-yiv-1696855592yiv7582130504logo {
padding-bottom:10px;}#ygrps-yiv-1696855592 #ygrps-yiv-1696855592yiv7582130504 #ygrps-yiv-1696855592yiv7582130504ygrp-msg p a {
font-family:Verdana;}
#ygrps-yiv-1696855592 #ygrps-yiv-1696855592yiv7582130504 #ygrps-yiv-1696855592yiv7582130504ygrp-msg p#ygrps-yiv-1696855592yiv7582130504attach-count span {
color:#1E66AE;font-weight:700;}
#ygrps-yiv-1696855592 #ygrps-yiv-1696855592yiv7582130504 #ygrps-yiv-1696855592yiv7582130504ygrp-reco #ygrps-yiv-1696855592yiv7582130504reco-head {
color:#ff7900;font-weight:700;}
#ygrps-yiv-1696855592 #ygrps-yiv-1696855592yiv7582130504 #ygrps-yiv-1696855592yiv7582130504ygrp-reco {
margin-bottom:20px;padding:0px;}
#ygrps-yiv-1696855592 #ygrps-yiv-1696855592yiv7582130504 #ygrps-yiv-1696855592yiv7582130504ygrp-sponsor #ygrps-yiv-1696855592yiv7582130504ov li a {
font-size:130%;text-decoration:none;}
#ygrps-yiv-1696855592 #ygrps-yiv-1696855592yiv7582130504 #ygrps-yiv-1696855592yiv7582130504ygrp-sponsor #ygrps-yiv-1696855592yiv7582130504ov li {
font-size:77%;list-style-type:square;padding:6px 0;}
#ygrps-yiv-1696855592 #ygrps-yiv-1696855592yiv7582130504 #ygrps-yiv-1696855592yiv7582130504ygrp-sponsor #ygrps-yiv-1696855592yiv7582130504ov ul {
margin:0;padding:0 0 0 8px;}
#ygrps-yiv-1696855592 #ygrps-yiv-1696855592yiv7582130504 #ygrps-yiv-1696855592yiv7582130504ygrp-text {
font-family:Georgia;}
#ygrps-yiv-1696855592 #ygrps-yiv-1696855592yiv7582130504 #ygrps-yiv-1696855592yiv7582130504ygrp-text p {
margin:0 0 1em 0;}
#ygrps-yiv-1696855592 #ygrps-yiv-1696855592yiv7582130504 #ygrps-yiv-1696855592yiv7582130504ygrp-text tt {
font-size:120%;}
#ygrps-yiv-1696855592 #ygrps-yiv-1696855592yiv7582130504 #ygrps-yiv-1696855592yiv7582130504ygrp-vital ul li:last-child {
border-right:none !important;}
