Joel Swan
On Saturday, the H23 finally hit the water. I've had the boat for just over a year but never was able to get it in the water last season due to mooring and slip availabilty (none), boat ramp access (most in the area are tidal which means I could get her in or out but not both on the same day), etc.Things went very well for a first launching. Stepped the mast twice. I forgot to attach the windex the first time but the practice is good. (In the rain of course.)Actually backed up the trailer without a hitch which was one of my nervous parts seeing that I had never used any type of trailer before.She just barely made it off the trailer. A few less inches and we would have had to wait fro another day.Powered down the river which was interesting. It's a tidal river with very few channel markers. Guessing where the river stayed deepest was a challenge but we made it without touching. The 9.9 four stroke worked admirably.Had to plow through some choppy waters at the head of the river. Tide going out plus wind blowing in made for some 2-3 foot waves. Pretty much plowed / feathered our way through until we got to clear water on the other side.Went to put the sails up. Little wind but you have to do it. FIRST problem. Jib sheets missing. The former owner said all was there. I saw a line all bundled up nicely which would have been a good one to use. Of course I made the mistake of never looking at the line. Ended up being four smaller lines bundled together.We jurry rigged a couple lines together so we could at least try to sail which worked okay giventhere wasn't any wind.QUESTION # 1Now I need to buy new sheets for the jib. Any suggestion on size / length for an 1987 H23?Lights all worked when on the trailer. AFter reaching the slip, the front bow light doesn't work. The stern light does and since there both on the same circuit, I hoping it's just a blown bulb form trailering, pounding through surf, etc.Second problem: VHF radio receives but does not transmit. Luckily (or actually due to numerous USPS courses) I had a backup VHF handheld with me. Needed this to get through a railroad bridge. The connector onthe deck for the coax looks somewhat suspect so I'm hoping that is the cause. Otherwise, I'll rely on the handlheld for the season.Third problem: Mast head light doesn't work (of course). I did check the bulb before launching and it was still good but made the mistake of not moving the mast to check to see if it actually lit. This connector also looks suspect so again, I'm hoping that's all there is to that.All in all. It was a great first launching. Although I am getting some funny looks in the slip. I'm using my slip for my 20 foot power boat until my mooring for the sailboat is ready. The other folks already in their slips are looking oddly at a sailboat in a row full of other power boats. Oh well.
