Tag Along Size
If you think about it, even the Titanic was on some sort of traile devise before launching, but you might need more than a V-8 to pull.Most states have a limit of around 8' in width before you need a permit for an oversize load. Length is relative, you should much more concerned with the weight of boat, trailer, engine, and "stuff" aboard. The towing weight determines what size tow vehicle is required.I tow an O'Day 26, total weight around 6500-7000 pounds, with a Chevy 3/4 ton van, 350 engine, trans cooler, and get about 9 MPG when towing. Towing weight is one of the big advantages to the newer water ballast boats, they will weigh in around 1500# less than a boat of equal size with an attached keel (fixed or swing).Hope this wasn't to confusing.Ben AllenMontgomery, AL"Latte Dah"O'Day 26
