E
Eric
I'd like to be able to get better sailing performance out of my Pilot House Motor Sailor. I'm going to put up a second head stay, parallel to my selftending, furling jib. I'll just use a halyard and hanks. Anyone got a suggestion, from experience, as to sail areas (125%, 150%, ??) that might increase the preformance to justify the investment. If anyone has hydraulic steering and needs suggestions for a rudder angle indicator. I took a piece of scrap aluminum and cut it to a radius just large enough to come through the teak rudder post cover in the cockpit. Attached it to the post, marked the rudder midship position, as well as max. and midpoints for travel in both directions. The only way I've found to tack successfully is to bring the boat about, is to set the rudder, and adjust direction and speed with the jib. It's almost impossible to sail with out knowing where the rudder is.
