large plastic looking washers on rudder bolt?
Jim Brown
Is there a replacement for the large plastic looking washers(spacers) on the rudder bolt? Mine are broken up pretty bad. Anyone tried casting them out of epoxy?
Dec 2, 1999
15,184
Cut them out of Poly.
Jim: I think you can find a plastics store and have them cut out of Poly. I do not know if Starboard would be any better but if there isn't any sun on them any poly should be fine.
Jim Brown
Thanks Steve -
They look to be about 1/8th X 4". I think I will fabricate them out of a thin poly cutting board and thin them up to fit with a belt sander. The old ones break up real easy - if you try to carve off a piece it just crumbles. I wonder if a little teflon grease would help. Thanks again Jim
Dec 2, 1999
15,184
Have you contacted Hunter?
Jim: I assume that you have a Hunter? You may want to contact them. Also McMaster Carr quite often has a lot of wierd items. These may be better to be made from nylon if they are that thin. You may be able to purchase a small sheet of nylon and drill them out with a hole saw of different sizes. If the outside dimension does not make much difference you can cut it out with a jig saw too. The biggest problem is getting the stuff cut without breaking it.
Jim
rudder bearings
Ome was nylon, and when mine took a dump I replaced it with teflon because it was available from the trash of a local plastics co. Am not so sure that it takes UV all that well (superficial cracks after three years) but for the price and performance I might do it again. The nylon unit I took off was nearly old enough to drink, and had never seen shade. Hope this helps, regards, Jim
