Good Idea! But there are drawbacks!
Laptops with drives can be power gobblers. Then there is the water resistence issue. For most sailors it is hard to keep a laptop handly on the cockpit due to exposure to moisture. Also, some laptops are hard to iew in bright sunlight.A good compromise is an inexpensive chartplotter at the helm connected via seatalk or NMEA to a laptop at your chart table below. Plan your routes below then upload your waypoints to the helm. Color is great but a B&W plotter is more than adequate. Don't spend a lot. You don't have to. Interface your laptop directly to your GPS antenna and you, in fact, have a bckup down below.Jon
