L
Larry B
I recently acquired a preowned '99 H 310 from a dealer who'd taken it in on trade. The boat sat unused for at least a few months, mabye an entire season before I got ahold of it. Other than learning the quirks, it seems to be working out extremely well, and I'm very happy with my new friend.My concern is that I have seen postings in this forum that indicate that either my knotmeter is fouled or not calibrated correctly, or my boat is moving through the water a lot slower than it should. I'm getting about 4.5kts under power at 3000 RPM in fresh water. I've never exceeded 5 kts under sail, in roughly 15kt winds.The hull speed rating, according to the specs, is 7kts. Someone has posted that they regularly exceed that number, which I find worrisome, given my experience.First question: are Hunters (or all sailboats) faster on salt water than fresh water?Second question: what should my expectations be, regarding hull speed under power vs. hull speed under sail?I haven't yet verified with a GPS. I guess that's the next thing to do. If that reveals that the knotmeter paddle-wheel is fouled, then the obvious solution is to clean or replace it. However, if it reveals that the meter is correct, then I am wondering what's going on.I have the original Raytheon (Autohelm?) instruments, but no manuals. I tried to figure out how to calibrate the knotmeter, but the method escapes me.I have the original 2-blade prop (Don't know about the size; I'll have to go under to measure it to find out). The Yanmar seems to be running well. I don't have anything to compare my experience with, however.Third question: would it be worth my while to replace the prop with a 3-blade? What would that accomplish, with regard to speed, acceleration, responsiveness, etc?Any and all feedback is much appreciated.Larry Bakerc/v "Flat Broke"Grapevine, TX
