Knocking sounds when sailing down wind
Avi
Sep 23, 2018
52
S2 9.2c Palacios tx
Hello everyone. I got a 1979 S2 9.2C, Yanmar 2Q15 engine. When I sail down wind, engine off and in neutral,I hear slightly knocking sounds from the transmission area. Looking at it no problem is visible. If I shift to Forward the noise goes away. I figure it is not detrimental to the transmission to stay engaged in gear with engine off while I am sailing. Any advice will be appreciated
Sep 24, 2021
386
Likely the shaft is turning from prop drag when in neutral... Check your manual, though.. Yanmar tends to not recommend putting transmission in reverse, and others definitely say NOT to put transmission in FWD under sail.
Do you have a folding prop? The knocking might indicate it needs service (sloppy blades). Alternately there IS a transmission issue that stops making noise when you lock it up.
Nov 6, 2006
10,145
Definitely NOT in forward.. That will glaze the clutch and cause a lot of wear..
Jan 7, 2011
5,818
Oday 322 East Chicago, IN
I would guess it makes the sound all of the time when sailing, but it is easier to hear when running down wind. You might want to check it (use AP or get someone to helm for you) and go below and look at your shaft, tranny, stuffing box, etc.
I believe Yanmar recommends shifting into REV if you want to lock the shaft while sailing.
I let mine free spin.
Greg
Sep 24, 2021
386
Pretty sure that Yanmar/Kanzaki combo says NOT to put in reverse, but to free wheel. Hurth/Zurn say to lock in REV but not FWD. However I suspect many yanmar users do shift to rev while sailing....
Jan 7, 2011
5,818
Yes, I think you are right. They changed the recommendation. I tried reverse one time, and I had a hard time shifting out of reverse and back to neutral.
Now I free wheel
Greg
Apr 22, 2011
958
Hunter 27 Pecan Grove, Oriental, NC
If the frequency of the knocking sound changes in relation to the speed of the boat, it could be caused by the prop shaft tapping against the stern tube. At least it was on my boat.
May 24, 2004
7,199
CC 30 South Florida
Follow Yanmar's recommendations which are sail in Neutral as the transmission is in constant lubrication as the prop turns the shaft. My exception would be if there is mechanical factor in the running gear which is causing a vibration or non-normal noise in which case I would place it in Reverse. Check the motor mounts, the prop shaft, the cutlass bearing, propeller and obviously the transmission. Do not place the transmission in forward as it will place undue wear on the clutch. When using reverse to stop the shaft from turning you must slow the boat to under one knot before shifting to Neutral to avoid stress on the linkage and internals of the transmission.
