2 cents
Hi John Your question is difficult to answer. I have a '78 h27,and have seen gusts to apprx 60kts,but not with full sail up. Our summer storms here in S.W. Fl. can be fierce. To answer your question flatly,I would guess a gust of 60kts would put your spreaders in the water. This would happen, say, after you were on stbd tack,and the gust caused so much weather helm,you will come thru the wind onto port tack,dead in the water, no headway and the gust would lay you over. Don't let this happen!!!Release sheets!!! Good luck red
