Got out on the water yesterday early before the winds kicked up.All speeds are GPS speed over ground. Typically ran a straight track for a half mile.Have noticed a definite change in speed vs rpm. First of all the max rated rpm is 3600 for the 3GM30, I was only able to achieve 3200. At that 3200 rpm the boat speed was 6.8, where I noticed the biggest difference was at lower rpm's. At 2000rpm spd was 5 - 5.4 on different courses, at 2500 rpm it was 6 - 6.4. At 2800rpm spd was around 6.8, so the difference at higher rpms didn't seem to help push the boat any faster. With this it appears I can run at lower rpms and still achieve a decent speed.Under sail, I was broad reaching with a wind of 5 - 5.5kts on two different tacks. Boat spead was running about 4.5 - 4.8, this is an improvement over the fixed three blade prop. The prop feathered as designed and at this speed had very little turbulence at the transom. Will need to see how this works when the speed starts hitting 6 and above. Wasn't able to get more data - the wind QUIT/DIED/WENT SOME WHERE ELSE. *cryQUESTION FOR THE COLLECTIVE: Will it hurt the engine to be run at 2000 - 2500 rpm range for long periods? I usually power along at 2800. I'll give another report in June after some more use.
