Check the photos link for photos of the head/holding tank installation on Whisper. The
head is a Blake Lavac, vacuum style. The holding tank was purchased through Boat Depot,
14 gallons, part number RH-B238. It came as a closed tank so we installed the fittings
where they worked out best for the system. We plan on adding some wood trim in front to
hide the tank. We followed the KISS system, which was posted on this group a week or so
ago. Basically, water comes in through the inlet, up a vented, siphon loop, into the head.
Waste water is pumped out with the manual pump, into the holding tank, and then if the
seacock is open, it goes out of the boat (the holding tank is above the water line, so
gravity empties the tank), if the seacock is closed, it stays in the holding tank until
pumped out. The total cost of the project was approximately $500 or so for all supplies
(toilet, tank, hoses, clamps, seacocks, etc.). We haven't tried pumping out yet, but so far
the system seems to be working great. Well, at least it isn't stinky...yet...
Kristen & Hans
s/v Whisper
Kristen & Hans
s/v Whisper
