Hi,
As you probably know already, I am putting in my new head system.
I am doing the KISS system like many of you have done. It will be a lot like Peter's when done.
I purchased the Jabsco compact head the other day. I purchased the least expensive model with the theory that if anything serious goes wrong - toss it and buy another one.
My question is on the Jabsco toilet.
They show a vented loop on the input side of the toilet when the toilet is below the water line. They specifically request that you take off the pipe that goes from the hand pump output to the top-back of the bowl, and replace it with the long loop. They don't want you to put it between the intake water valve and the toilet pump - which would be much more convienient (just loop up through the hanging locker to forward of the head compartment).
Our head is kind of half above and half below the non-heeled waterline.
Do we need this loop in our boat? Has anyone else with the KISS system not put in this loop and not had any problems?
Thanks,
Roy
#1813
_______________________________________________
Join Excite! - http://www.excite.com
The most personalized portal on the Web!
Thanks,
Roy
#1813
