King starboard
Bryan
I am interested in replacing some teak with "King Starboard". Has anyone used this material? Success? Suggestions? Thanks, Bryan
Jon Bastien
I used it for floorboards...
I've used it for quite a few things aboard 2 different boats. It's very easy to work with, has roughly equivalent strength as teak, and requires no maintenance or upkeep. Perfect for areas that will get wet (bilge, lazarettes, etc). I even made floorboards out of the stuff for my H23 when the original teak-and-holly finished plywood rotted apart. Had no problems with it. --Jon Bastien H25 'Adagio'
Pete
STARBOARD
is a marine grade plastic and can be used with any problems! This is the industry standard for marine use!
E
Ed Schenck
Also check plastic teak.
Does starboard come in a teak color? The link below, to Plasteak, illustrates plastic teak. It's made from recycled milk jugs. I recently ordered some for cabin trim. Only problem is color, it is not as dark as my varnished teak handrails. They also make the handrails but they are a bit pricey, $10-12. a foot.
Jack
PLasteak
I just saw a sistership to the one illustrated, it may have been the same one and I will tell you that it looked pretty good. I asked what it was because the finish felt strange but, unless you are a real purist, and you want a wood color contrast, this is a pretty nice alternative. It would be great for a cockpit grating unless it was too slippery.
G
Garry @ S/V TASHTEGO
Starboard
Just a note about some of the problems with starboard. First, it can't be glued without buying the special and very expensive glue they sell. Second, it is very (VERY) slippery. I have used it to make isolator plates for stainless fitting on mast and boom, for a grating in the anchor locker to keep the nylon rode out of the wet and for several other small projects. It's great stuff, strong and impervious to water.
