Slight differences, apparently
I presumed the 22 and 23 rudders the same, but apparently not. My 23 has no pin locking device up or down, just the cam cleat as Brian described to hold it down. I have never considered locking the rudder down, for it runs a few inches below the keel and when plowing furrows in the bottom of the Gulf, or pulling up crab pots, I like my rudder kicking up as an idiot warning. If it was pinned down, well, I just wouldn't have one by now. Anchored in weather I keep it down, in the slip I keep it floating, tiller tied, as Brian described. My lanyard is especially long, with a loop tied with a scaffold knot in such a manner I can slip it over the leading edge of the rudder holding it in an extreme up position for backing down the ramp. While sailing I've found what's important is that the line is the correct diameter so that the cam cleat gives while grounding, but holds as well when in heavy weather, when drag increases with sudden bursts excess of hull speed. Now let's offer this question to the forum: How did you deal with loss of your rudder? Mark Major, s/v Lesismor 86H23
