Kick up rudder "lock"
11
Catalina 22 nashville
There's a handle at the pivot point on my kick-up rudder....
I'm assuming it's a locking device of some sort, can someone elaborate, and where can I download a manual for my '75 catalina 22....
Dec 5, 2011
553
Catalina Catalina 22 13632 Phenix City
That handle is more of a friction device as opposed to a lock. I tighten mine just enough to hold the rudder in the down position while sailing but allow the rudder to move up if it strikes an object. Someone around here will know where your manual resides and steer you in the right direction.
Aug 27, 2011
408
Catalina 27 Titusville, FL
When I had mine, the friction lock handle didn't work, so to keep the rudder in the down position, we just used a 1/4-20 NYLON bolt with wing nut. Worked great, and in case of impact, it would shear easy. We always kept a few spares on board, but never needed them.
Apr 23, 2013
11
Actually I just want to be able to lock the rudder up when I'm recovering the boat out of the water, the line/clam cleat combo let go last time and I had to scramble to keep from damaging the rudder from dragging....
