Kenyon Mast Touch Up Painting?
26
ODay 23 Niantic, CT
I had halyard "slap" on the port side of my Kenyon painted aluminum mast (1980 ODay 23) and the cream colored paint is slightly worn. Is there a simple spray paint that can be used to "touch it up". I have an old Kenyon brochure that says "..anything from a marine or auto supply store will be fine..", but the mast painting threads I see here are for more complicated! Please let me know, thank you.
Jan 24, 2005
4,881
Oday 222 Dighton, Ma.
I remember seeing mast paint in the boat shows but I never paid much attention to it. Maybe they have some kind of a kit available on the market containing mix and match pigments for the mast. I don't know why you couldn't use automotive spray paint. There used to be an automotive paint specialist store on Route 44 in Seekonk Ma. or East Providence RI. They specialized in mixing and matching paints. All you would need is one of those Pre-Val air canisters with the small bottle attachment if you can get the right color match. Check Rig-Rite in Warwick RI. They may have this type of paint. Good luck with that.
Joe
Oct 20, 2008
26
ODay 23 Niantic, CT
Joe, Thank you for the information. I will follow up as you suggested, and post later on this site as I find out more!
Tony
Sea Drifter II
ODay 23
Niantic, CT
