Mike
Our galley is equipped with the original Kenyon stove/oven that uses kerosene to feed the two stove top burners and the one burner in the oven. The kerosene tank is pressurized with a hand pump to 10 psig prior to lighting the burners. The burners are preheated with alcohol poured into a cup at the base of the burner and lit. When the alcohol burns off, the burner flame adjustment valve is opened to admit kerosene to the burner. If all works right, a blue flame appears and cooking proceeds.Unpredicatbly, however, the burner flame turns yellow/white as if it is being flooded with kerosene, black smoke/soot then fills the galley. Don't know why it does this. When it happens the adjustment valve does not have much affect. I can only turn the kerosene flow off to stop the fire. Anyone had this problem and can suggest a fix? I'm at the point of getting rid of the stove/oven and use the space for something else. Has anyone shifted to propane or other source of cooking fuel? Can these stove/ovens be converted to propane?Thanks for your help.Mikes/v Charisma82 H36
