re Forced Air Being Dry
The people at Boat Electric, Seattle distributor for Espar, said that the forced air units put out dryer air than the hot water ones because the forced air brings in outside air. Richard is right, the forced air heats 100% outside air, or where ever the air supply is set up to get its air which is usually outside. Currently my air supply is in the lazarette (never finished installing it completely) which is open, but not big time, to the outside, and consequently it's a few degrees warmer than the outside.Pulling in outside air would be somewhat more inefficient than using inside air but with all the other inefficiencies involved I don't know how big of a factor that would be.Phil mentioned one other downside to the forced air units - they sound a bit like a jet engine when they're running! But you get used to it. My unit, which is about 10 years old, is reasonably quiet inside and it's not even soundproofed, so I'm okay with what little interior noise there is.Boat Electric said that the hot water unit was REALLY QUIET inside, so that's a plus for HW.Don't know if I mentioned it before, but the small size of the Hydronic vs the Forced Air makes it really appealing.The Hydronic takes a while to come up to temperature where as the forced air is really fast. If you've been away from the boat all day and go on board it will take a while for the hot water system to warm things up.
