Gettin' hitched
Thanks again guys, even more pearls. A couple of comments: I'm always jumpy about using a clove hitch on something like the sheet attachment to a clew, because it doesn't seem secure enough if the sail does any flogging - in other words, it strikes me as a knot that can untie itself under cycles of severe tightening/loosening/shaking. Is this an unfounded concern? Also, the idea of keeping the tail within the loop of the bowline makes good sense, possibly even to the point of adding a wrap of tape to keep it there. In fact, on halyard shackles I sew it in place with a few stitches. In the past we have used relatively long loops on the sheets so that it's easy to attach the whisker pole - the bowline allows this, whereas the other knots and hitches mentioned don't. But it does seem somewhat large, bulky, and heavy on light air days. And Don, if you use the inverted U-hitch on a single line sheet set-up, how do you keep the whisker pole from riding aft along the sheet? Finally, one of the best accessories on my boat is a roll of "gaffer's tape" my daughter donated from her job as stage manager. It is very strong, sticks well, comes off easily without leaving residue, and is great for bridging those gaps and crevices that seem to attract a loose sheet. We don't get many hang-ups (sheet-wise, at least) anymore since we started using that stuff.
