How to beat the heat!
Hello Kurt,Most people down here in Texas with a boat your size have a fixed mount marine A/C unit like those made by Marine Air Systems or Mermaid Air. A good description of an installed A/C unit in a boat your size (C320) can be found at http://www.catalina320.org/faq7.htm.These fixed mount A/C units are great when you have access to shore power. Your inverter won't have the capacity to supply juice to these A/C units away from the dock; so, you'll have to either add a genset or do without when away from the dock. Hella makes great fans that can be used on your boat. We have two on our C250 and they keep us cool . . . sweat evaporation really works during the summer.When at achor, an awning of some sort over select portions of your deck might also decrease cabin heat. The obvious solution is to direct as much air through your cabin as possible.Again, make sure to take a look at the link above. Larry Frank tells you how he installed a split system (two air handlers) in his C320.C250wb "Lorelei" #384
