Keep or replace turnbuckles
Aug 14, 2014
44
S2 9.2A Selby Bay, MD
I am going to replace my standing rigging with Norseman fittings/new rope this winter. I've read several articles/posts that indicate turnbuckles needn't be replaced as part of the re-rigging process. I'm curious to know what mfr was used as OE on the S2 (1984 9.2A) and what material the turnbuckles are made from It would be great to find out I can just clean up and keep the turnbuckles and replace only the pins.
I'd appreciate any feedback from those who have replaced their rigging and what they did specifically about the turnbuckles.
Jan 25, 2011
2,435
S2 11.0A Anacortes, WA
My 11.0 came with a closed up design turnbuckle with the pins being basically a formed coil spring with end being formed such that stuck through the slot and into the hole of the swags fitting. When I replaced the stdg rigging, I also replaced the turnbuckles with an open design and a plain cotter pin as they were 32 yrs old and the open design allowed for better inspection. I think the S2 Angelfire letter states the OEM.
Mar 20, 2012
3,983
In almost every case, if the turnbuckles are the right type and size, neither the turnbuckle or the pins need replaced anyore often then the chainplates do...
Inspect them with a magnifying glass and if damage is seen, replace them.
Its the cable that has the most issues, and usually where they disappear into the swaged fitting... when swaged, they take a tremdous stress and over the years with the vibrations of the rigging working as it does, and water intrusion carrying god knows what kind of chemicals with it that has been picked up in the atmosphere, and any freeze/heat damage, that the integrity of the swage connection becomes unreliable after several years. And its impossible to inspect with any accuracy...
So replacing the cables is recommended....
And when using the norseman fittings, it greatly reduces the stresses that is pressed into the cable strands when a swage fitting is installed, so the cable can actually last longer and is easier to inspect with some degree of confidence.....
caguy
Sep 22, 2006
4,004
A. guy in mastup tried that a couple of years qago and the threads though the same were really a sloppy fit. He finally did not trust them and replaced the turn buckles as well.
I've never broken a turnbuckle housing but I have snap a pin.
Sep 15, 2009
6,243
S2 9.2a Fairhope Al
i replaced my turnbuckles with new open body ones made out of bronze the original ones are ss closed body by CS Johnson and are prone to gauld with the ss toggles and terminals and when they Gauld it is a bear to get them moving or freed up ....i bought mine from SECO south in largo fl and they worked very well and the price was the best i could find....they also used to make hunters standing rigging but hunter was bought out and made a deal with there spar company to supply standing rigging along with the spars hope this helps
Nov 8, 2010
11,386
Your furling drum attached to a turnbuckle WITHOUT toggles. That was an accident waiting to happen. It failing was inevitable.
Aug 14, 2014
44
Thanks for all the feedback and info! I think I will clean/inspect and replace the turnbuckles as necessary. Of course if I decide to replace 1, I'll likely just go ahead and replace them all.
