As i will be removing the cutter rig on our 37 leaving it as a sloop, is there any reason in keeping the running backs?
Hey Blaise! I have nothing against sloops! If I wanted one, I just wouldn't have bought a cutterContrary to what Jim says, the boat as a sloop is the best cruising rig ever. You gain the foredeck to store a dingy on or sunbathe or whatever you want. You get rid of that ever present quandry of what to do with the staysail when sailing off the wind. Your tacks will be ten times faster. And if you want to strengthen your rig, the hardware is already there. Just add jumpers from the spreaders to the running backstay attachment points. One note of caution, if you don't install rails over your dorades, you will put one in orbit the first time you tack.
