keel
alymar
Jun 21, 2006
4
- - Homosassa,FL
How do you raise/lower the keel on my H22. I had a Venture 24 and it had a trailer winch for this task, my H22 has a line and cleat comming out of the housing. I seriously doubt that I can raise/lower the keel with this setup, as the boat is on a trailer it not possible to experiment on a system. Thanks in advance. Regards, Alymar
W
windrose
Centerboard not a keel
The H-22 has a centerboard and not a lifting keel. The board is fiberglass and has just enough weight added for it to lower. The centerboard raises and lowers with little effort with the equipment that came with the boat.
alymar
Jun 21, 2006
4
- - Homosassa,FL
Thanks WINDROSE!
I removed the setee and discovered the setup for lifting the centerboard. I also found the info that states that it has a fixed keel with a centerboard. It makes sense now, thanks again. Alymar
